Reload this Page >
Looking for Corsair tail wheel build
Old 08-13-2008, 07:28 AM
  #76
Duayne P
My Feedback: (15)
Default RE: Looking for Corsair tail wheel build
I LOVE THIS TAIL WHEEL. WOULD LOVE TO BUILD ONE. ONLY PROBLAM IS FINDING THE MATIRIALS. ITS KINDA HARD TO GET HERE IN GUAM. LUKE, I WAS WONDERING IF YOU BUILD AND HOW MUCH. PLEASE SEND ME AN EMAIL IF YOU COULD. NICE JOB GUYS.
DUAYNE
Old 02-12-2009, 04:00 PM
  #77
v6goose
v6goose's Avatar
*bump*
I'm building one and needed to find this again easily
Goose
Old 02-12-2009, 04:35 PM
  #78
DaddySam
My Feedback: (9)
I just bookmarked it.
Sam
Old 02-17-2009, 04:53 AM
  #79
Riddle4U
Well...Luke see how much we love you (and your tutorials)! Ha ha! It would be great to see you post anything here, and I hope yer grandest Corsair ever is in the works. I'm at it. I hope you're here (RCU), and I know most really appreciate it so much! Sincerely, -Eric
Old 08-05-2009, 08:31 AM
  #80
RCGuy41
I came across this build and have found it very interesting to say the least; I have a TF Gold Edition Corsair kit I'm going to start very soon. I have cut and paste the build instructions and can buy the majority of required building materials, but, PC Board were can I go to to purchase the material? Finally, I will also need a copy of the drawing to cut all the necessary parts for fabrication.
Question 1, I fly off of a grass field, will the tail retract assembly hold up on grass for take off and landing?
Question 2, What would be better to use a soddering iron or small butane welding torch during the build; I have both?
Question 3, What would the normal build time be for fab and construction, 10-20 Hr's?
Brad
Old 08-06-2009, 01:55 PM
  #81
chilie
To answer question #1: I have no idea! I have built one of these tail wheels and I'm still a long way from being done with the kit. My field has a dirt runway and it should handle it just fine.
Answer #2: Use a high quality soldering iron. At least 100 watts works well. I have had good luck using a 400 watt, you just have to be careful not to hold the iron on the material forever or it'll burn or delaminate. A torch isn't recommended.
Answer #3: I have found to really take your time and fit all the parts correctly you'll be looking at least 12 hours. With all the minor scale details added, it does take some time to complete everything. I'm sure there are guys who built it faster and that's fine for them. I prefer to take my time and have it look flawless.
As for where to buy the material, just do a google search for "two sided copper clad G-10" It will bring up many sites to find what you are looking for. I suggest you shop around since the price can vary a lot. I don't remember the site I ordered from, but I was able to get two sheets of 12"x12" board for about 9 bucks per sheet. You can build probably at least 4 or 5 tailwheels from that much material
Old 08-06-2009, 04:01 PM
  #82
RCGuy41
Chilie
Thanks for the answers to my questions, I have found the PC Board material, it's coming up from FL. The remaining items I should be able to find locally, wish I had a hobby shop which was local, its either order from the internet or drive one way 1 1/4 hour for hobby supplies.
Brad
Old 08-06-2009, 08:53 PM
  #83
Riddle4U
RC guy, I just went to radio shack. They seemed to be 6x12 sheets and probably not far out on price (double laminated). I think the lack of hobby shops is due to us buying conveniently from large mail-order houses instead of going to the local hobby shop. I am lucky in Denver...I hope it holds out! I have found many of the prices on big ticket items to be similar or maybe 5% more expensive. I am willing to pay more for stocked items at the L.H.S just to support their well-being! When you need fuel, or fuel tubing, or field support equipment, or props, glow plugs, glue, wood stock, covering material, knife blades, miscelaneous hardware (that wheel collar that fell off somewhere)...or even a replacement kit for your favorite that just dug a hole (and you want to get back on the horse immiediately); you hope the L.H.S. is there! It is also what keeps our hobby accesible to the newcomer with questions..e.t.c.! If they have what you want in stock, don't undercut their price by a few dollars, buy it, and support them for when you need the immiediate stuff! I am not a hobby shop owner..I just appreciate them being around, and hopefully nearby.
Old 08-06-2009, 09:44 PM
  #84
warks62
My Feedback: (140)
warks62's Avatar
I have built a few Tailwheels now and I only use a torche. Small crack type butane torche that many tool stores carry. But on the other hand I have had many years of welding and it just seems normal to me to use the torche. I guess it is what you are used to using.
Old 08-15-2009, 08:30 PM
  #85
RCGuy41
Gents, I have started building my Corsair Tail retract. I have made two mods; one to the wheel bracket and the other to part B. I noticed a small amount of play after soldering so I added L bracket to provide better support; then I added some L bracket to part B to provide a abetter solder point. Please review my work and some feed back.
Brad
ID:	1256807   Click image for larger version
Old 08-30-2009, 12:32 PM
  #86
RCGuy41
Hi Gents,
Well, after building my first prototype gear it turned out, well lets say bad. I took the entire gear apart and started all over again, this time I squared all parts and sanded to closer tolerances. Now I have completed my second 1/8th Corsair tail retract build here's a few pics of my retract. Next I will cleanup the retract and add some curves and then prime and paint.
Brad
ID:	1265874   Click image for larger version
ID:	1265875   Click image for larger version
Old 08-30-2009, 01:12 PM
  #87
WhoDaMan
My Feedback: (164)
WhoDaMan's Avatar
Brad, All I can say is at least your trying, I had to have mine built,,, Great job
Dave
Old 09-01-2009, 03:11 AM
  #88
Riddle4U
Looks pretty good to me Brad...stick to it! Only you could really know how strong the soldering is (that's the important thing). You can sand and grind to your hearts content after that (wear a good mask). It'll look nice after you prime and paint it (having done all the filling). Stick with it.
Old 09-01-2009, 08:58 AM
  #89
RCGuy41
Dave, Riddle4U
Thanks for the compliments, one item I noticed was the aluminum shock piston and brass sleeve being soldered to part A there was no give during compression. As you all can see I used a 3/32nd brass tube; I drilled through the 7/32nd brass tube and the aluminum piston to insert the 3/32nd brass tube. For some reason when I drilled out part A for the 7/32nd brass tube it came out approximately 1/64th of an inch larger, giving the 7/32nd brass tube some play. That's when the idea came to mind to insert the 3/32nd brass tube and it worked and now I get approximately 1/2 to 5/8 of an inch travel on my shock strut. A plus on my side; I can take the shock strut apart for cleaning and spring replacement when needed. I have few more ideas to improve on the design, but that will come later.
Brad
Old 09-10-2009, 06:48 PM
  #90
RCGuy41
Gents,
I'm finaly done with my 1/8 scale Corsair tail wheel retract, less tail hook. I have a few ideas to try and improve on the original design, this fall I'm going to be cutting and shapping a few new parts. The only thing I wish I had was a small lathe to work a few of the parts, but oh well maybe next year. Here are a few pictures, any comments will be greatly appreciated.
Brad
ID:	1272480   Click image for larger version
ID:	1272481   Click image for larger version
Old 09-25-2009, 03:56 AM
  #91
Riddle4U
Why don't you join our 1/6th Corsair build? We are all in various stages, and some of us are slow or stalled out on building; others are pressing forward quickly. I have just concentrated on flying this summer for a change. I have had fun and cleaned oil off my sport model a few times. I am ready to build my TW, and you will be amongst Corsair fans. I think we are 1/6th Corsair blaa bitty blaa (search for 1 sixth corsair on RCU and you'll find us). -Eric
I noticed you're building a 1/8th...so what. Check our project out!
Old 05-01-2010, 11:11 PM
  #92
RCAlan
I see the last  entry  in this thread is  8 or 9 months ago, so hope someone  checks back here.
I would like to build the 1/8 corsair tail wheel.
At the beginning of the thread  reference is made to the plans.
How do I get the plans ?
Alan
Old 05-02-2010, 09:48 AM
  #93
chilie
Yeah people still use this forum
Here are the plans that I drew up. I have made some minor modifications to the original drawings that I created (such as a different way to make the shock absorber). You can use them as you wish. When you send them to print, be sure to select "no page scaling" so it will print correctly.
File Type: pdf
Old 05-02-2010, 10:12 AM
  #94
RCAlan
Thank you chille
Much appreciated.
Looks like I will be busy this fall and winter.
Alan
Old 05-03-2010, 08:27 AM
  #95
v6goose
v6goose's Avatar
Good job Chilie...
Old 05-03-2010, 11:14 AM
  #96
chilie
I do what I can
I haven't been working on my corsair project for too long. Sooner or later I gotta get back into it.
Old 08-16-2010, 06:55 PM
  #97
RCGuy41
Chilie,
Thanks for posting the updated instructions, I'm just about finished building a Corsair tail retract for another member here is what it looks like.
Old 08-16-2010, 07:42 PM
  #98
n8622t
My Feedback: (8)
Hey Samparfitt, that was on an rcu youtube video, I just watched it three weeks ago here it is
http://www.youtube.com/watch?v=IQHf7F1qFY8&feature=fvsr
Old 08-17-2010, 11:09 AM
  #99
chilie
Thats a mighty nice tailwheel. I'm glad you enjoyed the building experience. I don't think I've ever worked so hard on a small part that largely won't be seen by most!
Old 09-05-2010, 12:49 PM
  #100
p51tom
I have done some modifications to this design so it will fit in my EMS 75" ARF Corsair. I changed the method of retraction to make it more compact. Over the past 42 years I have built 3 Corsairs ( Royal, Brian Taylor 76", & Topflight 86") and sold them all. I do miss these Corsairs therefore I bought the ARF which I am improving by adding some detail and changing the flaps and tailwheel. I have added photos to show the tailwheel, my TopFlight Corsair, and some of the the modifications to my ARF.
ID:	1495662   Click image for larger version
ID:	1495663   Click image for larger version
ID:	1495664   Click image for larger version
ID:	1495665   Click image for larger version
ID:	1495666   Click image for larger version
ID:	1495667   Click image for larger version
ID:	1495668   Click image for larger version
