Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
Quick OFNA Truggy gear pitch question
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 05-04-2024, 02:37 PM
byggd
Default Quick OFNA Truggy gear pitch question
I'm converting an old MBX R2 (truggy conversion years ago) to brushless. Neither 32P or 48P mesh with the spur gear. What pitch do I need?
Old 05-05-2024, 08:17 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Was it electric to begin with?
Old 05-05-2024, 11:21 AM
byggd
No, it was a nitro buggy converted to a nitro truggy.
Old 05-05-2024, 02:16 PM
byggd
After much digging it turns out old "vintage" OFNA MBX R2 Nitro 1/8 buggy used 22P bell pinion / spur gear. No 22P 5mm pinion gear on the market that I can find.
Old 05-05-2024, 04:43 PM
bill_delong
bill_delong's Avatar
I feel like a broken record:
OFNA Spur Gear Question
That link I posted is the most economical part that is likely compatible from the same OEM
According to this manual here for the Ultra MBX R2 they specify the stock spur as #31040
https://www.manualslib.com/manual/76...?page=6#manual
https://www.ebay.com/itm/175835724837
I've ran enough HongNor cars that chances are you may get a full diff to work as well if you measure the bearings and distance between the slots in the diff mount then ask someone on RC Tech to measure and confirm:
https://www.ebay.com/itm/255127759402
After you take your measurement (outer bearing to outer bearing) and verify bearing diameter, then ask someone on this thread to confirm measurements:
https://www.rctech.net/forum/nitro-o...in-x1-crt.html
Old 05-06-2024, 06:55 AM
byggd
I still have the original center diff and it includes the 31040 spur gear. When the truggy kit was installed, it included a solid shaft to replace the diff and an ONFA 18163 65T spur gear to compensate for the larger tires. Neither the 31040 or 18163 spur gears have a 32 (or 48) pitch. The bell clutch / 31040 and 18163 spur gears have a 22P. So purchasing the 31040 will not work when converting to brushless.
Old 05-07-2024, 06:24 AM
bill_delong
This is why I said it would be easier to swap out the entire diff with one that uses standard MOD1 gears
Old 05-08-2024, 02:37 PM
byggd
That would work, but I find a solid center diff works better for bashing! :-D
