Zeus
Old 06-12-2018, 02:39 AM
  #176
RodneyFord
RodneyFord's Avatar
I've been able to have a rough balance up and the CofG is going to be pretty much where I designed it. So I can now make the UC legs. Here is the profile on the CNC foam cutting PC.
Cutting the extruded foam block.
Mylar Vac bagged onto it with PU glue.
Old 06-13-2018, 01:01 PM
  #177
RodneyFord
RodneyFord's Avatar
Spinner cone straight out of the mold. Flashing yet to be removed.
Old 06-13-2018, 05:33 PM
  #178
RodneyFord
RodneyFord's Avatar
UC mold ready with dams in place.
20 layers of UNI carbon and 2 of 45 degree bias cloth on the outside.
In the bag with 2 layers of breather soaker. Quite a bit of resin coming out so I changed out the soaker after this. I am using slow hardener and it is now in the electric blanket. The heat should reduce the viscosity of the resin and allow it to be soaked up before it goes off.
Old 06-13-2018, 10:07 PM
  #179
RodneyFord
RodneyFord's Avatar
Made a spinner back plate from 6mm ali plate. It still needs the spokes cut.
Fit is OK. I will be painting it white with red flash on the front. Better get on with that prop.
Old 06-14-2018, 03:31 AM
  #180
RodneyFord
RodneyFord's Avatar
Legs came out OK apart from being twice as heavy as they should have been. Will have to remake them with 12 layers of Uni and 1 layer of bias cloth.
Old 06-14-2018, 08:38 PM
  #181
RodneyFord
RodneyFord's Avatar
Got the first wing panel into the press.
Old 06-15-2018, 11:37 PM
  #182
RodneyFord
RodneyFord's Avatar
I made another pair of legs with half the carbon. 10 layers of uni and one of cloth.
The legs have some flexibility now.
Old 06-16-2018, 05:18 AM
  #183
jim woodward
Cheerleading from Florida - its really amazing you have all the tools and skills to completely manufacture these items like you are!! Jim
Old 06-16-2018, 05:44 PM
  #184
RodneyFord
RodneyFord's Avatar
Cheers Jim. I just count myself luck that I have the time to do this stuff. When my next contract turns up it will all stop.
Out of the press after over 40 hours.
Untrimmed weight and it has lost 16gms since taking it out of the press 3 hours ago.
Next one in the press. It is nice to be able to check how straight the trailing edge is. I torque the nuts down by feel more at the root than the tip. I think it must be possible to work out exact amounts of torque to allow for the different area each bar is compressing.
Old 06-16-2018, 09:22 PM
  #185
RodneyFord
RodneyFord's Avatar
Got the elevator and rudder tray in.
Old 06-17-2018, 12:27 AM
  #186
RodneyFord
RodneyFord's Avatar
There's mini me in the background piloting my Slick. 3D printed scan.
Printed these rudder horn fairings.
Old 06-18-2018, 08:28 PM
  #187
RodneyFord
RodneyFord's Avatar
Second wing panel is out of the press an is 10gms lighter at 258 gms. Had another balance up checked my measurements and drilled the wing tube holes in the fuselage. Had a preliminary weigh up and I'm pretty confidant it will make weight. I might even be able to fit a Tcan. My muffler build is not going well, so i am reviewing my options on that.
Old 06-19-2018, 12:29 AM
  #188
grahamj4
Rod that is looking fantastic!! Looking forward to seeing it fly :-)
Old 06-19-2018, 01:41 AM
  #189
workers
Loving this build, exceptional skills. Its great to see how composite work is done in such detail.
I also cant wait to see how it goes with a da50!
Had a few 50cc extras etc with da50's and most would pull out of a hover at half throttle, weighing about 17-18lb. The prop you showed that you're replicating could you make that a 3 blade?
Also Im wondering if 8"+ pitch would be too fast?
Anyway it will be fun finding out!
Great work.
Dan
Old 06-19-2018, 02:34 AM
  #190
RodneyFord
RodneyFord's Avatar
Cheers Dan and Graham. Well the DA 50 can certainly afford to be de-rated. A 3 blade prop would be good but I didn't want the complexity of building one that is why I went for the wide 2 blade. This is what is known as blade solidity or the ratio of blade area to swept area and this wide blade should be fairly similar to a normal 3 blade. As for pitch, I suppose it is really about down line braking but it's all a bit of an unknown due to the high volume/drag of this fuselage although I have done a fairly slippery wing. As you say it will be fun finding out.
Old 06-19-2018, 09:10 AM
  #191
Anthony-RCU
Anthony-RCU's Avatar
Ch
Dick Hanson used a similar system using automotive valve springs. The springs had a known rate so by measuring the compression he knew the force exerted.
Old 06-19-2018, 01:00 PM
  #192
RodneyFord
RodneyFord's Avatar
Yes I see Dick is still posting and he mentioned recently that the press was his preferred method. I can see how the spring method would work. I do prefer the vacuum bag and I am well set up to do it including a back up compressor and vacuum tank with Festo vacuum switch. The reason I used the press was the PVA glue needing to air dry. I will be going back to bagging for my next project as it will have no honey combing and a full paint finish.
Old 06-20-2018, 03:12 PM
  #193
RodneyFord
RodneyFord's Avatar
Made titanium axles screws and washers for the UC. Still a bit left for nuts
Titanium machines nicely just hard on the cutting tools.
Good savings to be had
Old 06-20-2018, 08:04 PM
  #194
RodneyFord
RodneyFord's Avatar
Made rubber washers and shock pads for UC mounting. Brass tube drills with water lubricant.
Old 06-20-2018, 08:12 PM
  #195
RodneyFord
RodneyFord's Avatar
Set up the wing.
Glued in the donuts.
Old 06-21-2018, 05:24 PM
  #196
RodneyFord
RodneyFord's Avatar
First look assembled. 3.8 kg like this with motor, header and one servo.
Old 06-21-2018, 07:20 PM
  #197
RodneyFord
RodneyFord's Avatar
Wasn't having much joy with my custom can so I have gone with this commercial item. 210 gms but it should be quiet.
Old 06-22-2018, 12:16 AM
  #198
grahamj4
Impressive Rod! You're getting me inspired to have a go at this myself!!
Old 06-22-2018, 04:51 AM
  #199
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
It would be nice to see more guys building their own models. The hobby overall seems to have lost the craftsmanship aspect.
Old 06-22-2018, 10:20 PM
  #200
RodneyFord
RodneyFord's Avatar
I'm OK with this as it is a time/money/skill thing. We are still seeing some beautiful models popping up pretty regularly (such as yours). I'm liking what I'm seeing in the Classic Pattern scene. I have a couple of projects in the pipeline there.
