Pattern Biplane
Old 06-03-2018, 11:49 AM
  #326
kenh3497
kenh3497's Avatar
First day of a contest with an "unknown" airframe... I'd say you did OK. Second day the jitters kind of go away and you and the plane calm down. LOOKING GOOD!!!
Ken
Old 06-03-2018, 06:27 PM
  #327
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Well, it didn't work out as well as I had hoped contest wise but I came home super stoked anyways. The first round this morning was to be an unknown. Not a major deal as we were just supposed to fly the next class lower known sequence. I had judged 2 rounds of intermediate on Saturday so I didn't think it would be a big deal. Well after a top hat there was some confusion between my caller and I that resulted in me not performing the next maneuver. 4 zeros in that round. Final placement was another 4th place. My lack of flying during the Divergent build still has a firm grip on me.
Now the good news, pattern guru Tony Frackowiak must have seen something he liked in the airplane and had asked if I would let him take a flight. After sorting out a rudder trim issue that eluded me he started flying through some FAI sequence maneuvers. Tony made the airplane do things that looked so effortless. He did some inside and outside snap rolls and commented on how well it kept track during snaps. He also commented on how well it flew through rolling loops. His only criticism was that he felt the CG was a bit aft and that it needed a bit more right thrust which is what I was trying to compensate with the rudder trim. He also commented on the very positive rudder authority. I am very pleased to know that the design is capable in the hands of a legend of our sport. After hearing Tony's comment I did say that after a few more additions to the Divergent tooling that I may be ready to start some limited kit production. Tony asked that his name be added to the list of interested parties.
Old 06-03-2018, 06:29 PM
  #328
speedracerntrixie
My Feedback: (29)
Pictures of the weekend.
Old 06-04-2018, 07:14 AM
  #329
Pylonracr
Pylonracr's Avatar
Well Shawn, at least you have finally broken your curse of always finishing second.....
Old 06-05-2018, 04:31 PM
  #330
speedracerntrixie
My Feedback: (29)
Not really the direction I wanted to go. At least now I know it is my flying that needs to improve and the airplane is solid. I need to get an actual practice schedule going and stick to it. Flying only a couple times a month is just not cutting it.
Old 06-05-2018, 05:03 PM
  #331
flywilly
My Feedback: (121)
'Tony asked that his name be added to the list of interested parties.'
That is a pretty impressive endorsement!
On the plus side it means all the hard work was worth it! On the minus side... it means the improvement needs to come from the pilot; as you noted, more practice. The trophies will come...
Great Job, Shawn!
Good luck the rest of the season!
Old 06-06-2018, 05:08 PM
  #332
kenh3497
kenh3497's Avatar
Well Shawn, I always say things have to get worse before they get better. Things have gotten worse so now they WILL get better. Very impressive with the endorsement!
Ken
Old 06-07-2018, 12:49 PM
  #333
speedracerntrixie
My Feedback: (29)
I think that practice and just plainly getting more time on the airplane will really show up in contest performance. Although it will be a bit tough I have made the decision to clean house a bit. I am going to sell/give away some current projects in order to free up more time for actual flying. I have a classic I want to finish up and then I will be making a pre production Divergent kit then do a cost analysis on it to see if it is a feasible venture to make ARC kits. My estimate at this point would be they would run in the 1,800.00 range.
Old 06-07-2018, 07:59 PM
  #334
Pylonracr
Pylonracr's Avatar
Shawn, since you are cleaning house I will give you 20 bucks for that junk Polecat kit you have that is just taking up valuable space...................
Scott
Old 07-21-2018, 06:46 AM
  #335
speedracerntrixie
My Feedback: (29)
Still fighting some gremlins, hopefully fixed. During the last contest my Hacker died during round 2. I suspect that I did not have enough cooling air exit area. I made a decision to install a Dualsky 6355 DA-12 motor that I had been flying in my Hydeaway for over a year with zero issues. Well, that changed about 30 seconds into the test flight with the different motor. What I beleive happened is that the motor connectors were too loose and would not allow good current flow which caused the motor to stutter or cog. The result was that the motor and ESC ejected out the front of the airplane. The good news is that with over a pound of weight off the nose, I was still able to keep the airplane under control and land without further damage. The lesson was learned and a new mount was fabricated, new correct fitting motor connectors were fitted and the damage was repaired. At this point the Divergent has 16 flights with the Dualsky outrunner and has never flown better. Now back to trying to free up time for practice.
Old 07-21-2018, 09:12 AM
  #336
Hans S
Hi Shawn, short Question:
Which ESC are you using with Dualsky 6355?
Old 07-21-2018, 09:42 AM
  #337
speedracerntrixie
My Feedback: (29)
Hans, I am using the OS OC1100HV. I really like this particular ESC and really wish they were easier to get here in the US. R/C Japan have them listed and I tried to order one over a week ago but sadly have yet to receive an invoice from them.
Old 07-21-2018, 02:49 PM
  #338
wingster
My Feedback: (26)
I just received the Futaba version(MC9100A) from Perth RC in Austraila. Shipping was about $25 and the price is reduced 10% because of the VAT tax. The price is in Aussie dollars so multiply by approx. 0.75.
FUTMC9100A MC9100A speedie for 90-110 class motor Li-po 4-12s
Old 07-21-2018, 03:20 PM
  #339
speedracerntrixie
My Feedback: (29)
Great! Thank you very much.
Old 07-21-2018, 03:49 PM
  #340
drac1
drac1's Avatar
Hey Sean,
Maybe check that you have actually ordered it correctly? It's very unusual that you haven't had a reply. I always get a reply within a day, even on weekends.
Old 07-22-2018, 01:22 AM
  #341
Hans S
Thanks Shawn, I use a OS/Futaba clone from Multiplex (ROXXY 9100-12).
https://www.hoelleinshop.com/All-you...=68754&p=68754
But I have some screeching at 80-90 % Power with Dualsky 6355-12 V3.
What Settings are you using?
Old 07-22-2018, 05:14 AM
  #342
speedracerntrixie
My Feedback: (29)
Default Esc
All settings are default except timing is 20 degrees and brake is 10%.
Old 08-14-2018, 03:45 PM
  #343
speedracerntrixie
My Feedback: (29)
It's been a while but I finally have some pictures of the Divergent in flight. These were taken while just horsing around at a local club field.
Old 08-14-2018, 06:56 PM
  #344
kenh3497
kenh3497's Avatar
I don't know if you noticed but somebody vandalized your spinner. They hacked the tip off......
Ken
Old 12-09-2018, 04:23 PM
  #345
speedracerntrixie
My Feedback: (29)
I haven't updated the tread in a while, not much flying lately. I have all the nesessary materials in house for a couple kits. Very few changes will be made. I'm currently making molds for a slightly longer landing gear for a bit more ground clearance, molds for the wing fences which will be a bit smaller and the rudder will have a bit more taper top to bottom. A slightly different fuselage layup should yield a bit less weight as well.
Old 12-09-2018, 07:45 PM
  #346
Pylonracr
Pylonracr's Avatar
Ken
It came like that Ken, it was on sale. Half price...
Old 12-09-2018, 08:25 PM
  #347
speedracerntrixie
My Feedback: (29)
You know me, I don't pay full price for anything. Well wait, except GM transmissions. I end up paying double for those.
Old 12-11-2018, 07:27 PM
  #348
kenh3497
kenh3497's Avatar
ha ha ha. I'm still amazed at the lengths some MFG's go to to build a better mouse trap. Most if not all cowls have a built in air scoop. All that is needed is to properly direct the air to the motor much like you would do with an IC engine.
Ken
Old 12-11-2018, 08:24 PM
  #349
speedracerntrixie
My Feedback: (29)
A little more to it then that with electrics Ken. One of the side air intakes has a duct that directs air directly onto the motor. The spinner in a standard Great Planes unit that has an aluminum backplate that I cut the tip off of to get a bit more air to the motor. The bottom air intake and the second side intake provide airflow over the ESC and batteries. An electric actually has the potential to generate more heat then a glow engine.
Old 12-15-2018, 09:24 PM
  #350
Pylonracr
Pylonracr's Avatar
Hate to admit it Ken, but the little pin head is right. Electric motors generate quite a lot of heat. The best way to cool them is with the open spinners. This forces the cooling air directly over the hot motor, all of this assumes proper hot air exit area is designed into the airframe. In the case of this UGLY plane, proper hot air exit area Has been designed into the fuselage. It does work.....
Scott
