Pattern Biplane
Old 01-27-2018, 09:07 PM
  #276
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
More good progress. I got the stab guide tube in and stabs leveled. The lower wing mounts are done as well. Tomorrow's tasks will be to glue in the fin post and lay up the hatch and a wheel pant.
ID:	2252422   Click image for larger version
ID:	2252423   Click image for larger version
Old 01-28-2018, 05:25 PM
  #277
speedracerntrixie
My Feedback: (29)
A hatch is born. The fit is pretty darned good.
Old 01-31-2018, 06:57 PM
  #278
speedracerntrixie
My Feedback: (29)
Getting closer.
Old 02-08-2018, 07:02 PM
  #279
speedracerntrixie
My Feedback: (29)
All the wood surfaces have been finish sanded and are now ready for glassing. It's in the home stretch.
ID:	2253961   Click image for larger version
Old 02-08-2018, 08:11 PM
  #280
Pylonracr
Pylonracr's Avatar
OK, I give up. Where the Hel* did you fine green grass???
Getting there, still on the path for target weight?
Scott
Old 02-09-2018, 07:03 AM
  #281
speedracerntrixie
My Feedback: (29)
Pretty sure this one will make it. I threw all servos, batteries, speed control, prop RX and anything else I could think of that will eventually go into it and it came out at 10 lbs even. That gives me a pound for glassing and painting along with some hardware. I'm pretty certain that with some changes to the fuse layup I can pull a half pound out of the next one.
Old 02-11-2018, 07:06 PM
  #282
speedracerntrixie
My Feedback: (29)
All the surfaces are glassed. I will give them a couple days to cure and then they will get blocked out with some 320 grit. I haven't removed the ailerons or elevators as of yet. I figured it would reduce the numbe of parts that I would have to glass and it should keep the control surfaces a better fit when they get hinged. I also fabricated up some wing fences that have tabs that will protrude through the outer surface of the wings tomthe inner surface where these tabs will become the strut mounts. I still have to finish the strut plug and then pull a mold from it. I also felt the need to put some bushings into the fuselage where the upper wing anti rotation pins insert. Right now the CF pins interface with a CF plate, not the best for long life. Problem was I could not find any the correct size. Solution? Make them myself out of fiberglass.
ID:	2254354   Click image for larger version
ID:	2254355   Click image for larger version
Old 03-13-2018, 06:05 PM
  #283
speedracerntrixie
My Feedback: (29)
Things have been progressing a bit slow but I am on a good pace now. All surfaces have been hinged, everything is in primer and I am waiting for some nice painting weather. We have rain for the next couple days.
ID:	2259141   Click image for larger version
ID:	2259142   Click image for larger version
ID:	2259143   Click image for larger version
Old 04-02-2018, 08:16 PM
  #284
speedracerntrixie
My Feedback: (29)
Painting is progressing well.
Old 04-03-2018, 04:24 AM
  #285
flywilly
My Feedback: (121)
Looks Great! What are you using for paint? Will you clear coat? Thanks!
Old 04-04-2018, 06:58 AM
  #286
apereira
apereira's Avatar
Looking really good!
Old 04-04-2018, 08:20 PM
  #287
speedracerntrixie
My Feedback: (29)
Most of the paint is Duplicolor lacquer over Klass Kote primer. There will be a urethane gloss clear applied.
Old 04-05-2018, 05:26 AM
  #288
kenh3497
kenh3497's Avatar
FWIW.... On one of the FB groups somebody was using white epoxy primer and adding West Systems 410 microlight filler. I believe he mixed equal VOLUME of filler and primer. It was used as a high build primer. Very easy sanding and very little weight gain. A normal mix of primer was then used as a white base to paint on.
The Divergent is looking very good Shawn! Can't wait for it to get some clear on and assembled.
Ken
Old 04-06-2018, 06:34 AM
  #289
speedracerntrixie
My Feedback: (29)
Ken, I've done the same thing with Klass Kote primer and micro balloons. I managed to get the shiny stuff on and get her on her legs. Servo/linkage install is the only thing left. Now if only the weather would cooperate.
Old 04-06-2018, 07:19 PM
  #290
Pylonracr
Pylonracr's Avatar
Weather??? What, you can't install servos if it is raining outside?? The plane is inside your house. Stop me if I am going too fast for you.
Scott
Old 04-07-2018, 06:43 AM
  #291
speedracerntrixie
My Feedback: (29)
Ha ha, I would rather not maiden in the rain........ that and I would really like to get some pictures of it fully assembled in the grass.
Old 04-07-2018, 11:12 AM
  #292
Pylonracr
Pylonracr's Avatar
Wait, Wait, Wait.....You are going to fly this thing????? I thought it was a static display plane to hang from the ceiling.
I was expecting you to bring it to my lake house this summer, fill it with candy, and use it for a pinata......
Where did I go wrong????? I was sure we talked about that last year........
Seriously, it is looking good. How is the weight? Still under?
Scott
Old 04-08-2018, 10:31 AM
  #293
speedracerntrixie
My Feedback: (29)
It's getting close, all that's really left is the servo and linkage install. It is a bit heavy according to my bathroom scale but that is with my heavy 5000 mah batteries and a few items that could be lighter such as wheels and some additional wire. I can also do a bit of cut and polish on the clear to remove a bit of weight. With a few minor changes it can be brought down to 11 1/3 lb. I have learned enough building this one that I can apply and with a less flashy paint job and film covering on the wings and stabs it is possible to have one come out at 10.5 lbs.
Old 04-08-2018, 10:37 AM
  #294
R_G
R_G's Avatar
Beautiful workmanship! Very nice!
Ralph
Old 04-08-2018, 10:47 AM
  #295
Pylonracr
Pylonracr's Avatar
Looks good Shawn. Not going to have any trouble seeing it.
Scott
Old 04-08-2018, 03:49 PM
  #296
kenh3497
kenh3497's Avatar
My OH MY..... That is really sharp. I LIKE IT!!!!!! With the wings on it's look changes completely. It looked good before but now is awesome!
Ken
Old 04-17-2018, 08:13 PM
  #297
Pylonracr
Pylonracr's Avatar
Yo Shawn, have you flown the Pinata yet. Are we going to fill it with candy this July at my lake house????????
Old 04-18-2018, 12:35 PM
  #298
speedracerntrixie
My Feedback: (29)
Default First flight
I’m just finishing up on the radio install now and then the only thing left is stut mounting and then a good bench setup. The first flights will happen on Friday.
Old 04-18-2018, 01:45 PM
  #299
Pylonracr
Pylonracr's Avatar
Not too bad Shawn. Last July that thing was an idea and some drawings on a piece of paper and we were kicking around composite ideas and methods at my lake house. Less than a year later and it is ready to fly with production molds. I like it. Still ugly, but I like it......
Scott
Old 04-18-2018, 04:46 PM
  #300
kenh3497
kenh3497's Avatar
Originally Posted by Pylonracr
Not too bad Shawn. Still ugly, but I like it...Scott
I always liked it. Sometimes less and sometimes more. haha Now that it is complete and painted it all comes together nicely. From my perspective it was quite the effort to do. From Shawn's perspective I'll bet he is glad the project is almost complete. I would have been burned out long ago. I can't wait for the first impression flight report. Of course with a pattern or any plane for that matter you never really know how it flies until you get 30 or 40 flights on it.
Great job Shawn!
Ken
