T-One Landing Light Interface Question
I have T-One with the installed light set. It is the light set that is provided by the OEM. The Landing Lamp on the nose gear has an interface attached to it. The two inputs to the interface are identical. They both have JR Connectors and both have all three wires attached to the board.
I assume one is power for the lamp and the other is the signal circuit to turn on and off the lamp. This signal actually would come from the Landing Gear controller's second servo door port, I think.
Question is: Which lead to the interface is the power or which one is the signal lead? I attached a picture of the interface.
Question Answered
Dirk put together a really nice set of pics to show the T-One's Nav Light setup. Thank you Dirk! I attached it here for future reference for all of us.
I'll also add that the T-One came as advertised. It was packaged really well and the components were flawless. The custom paint job appears flawless.
I assembled it in the same order as my Ultra Flash and every thing went together very well. Fit and finish are outstanding. I may maiden this weekend!
Some of my club's members have stated that they are reluctant to put up the entire amount of $s upfront. But rest assured that the entire process that I went through was flawless and the jet even came a bit earlier than advertised. The wing bags even fit perfectly and are well designed to protect them.
Bottom Line: I personally endorse Pacific RC Jets T-One product and process!
