Reload this Page >
CARF Joker build thread
Old 10-17-2018, 10:05 AM
  #451
Dave Wilshere
When the tank is in front of the balance like the Joker I balance with a reasonable amount of fuel...or its super nose heavy till you land! I decided fly my Joker without filling the tank last week (not on purpose!) and even then the balance felt safe...right until the MAP bubble trap had 1oz in it and the turbine stopped coming past! Luckily its a good glider and I did a full circle and landed.
I'm guessing 25mm in front of the wheel axle with 1/4 tank will be about right.
We always give a conservative balance to allow for a wide range of control set ups and stick operation!!
Old 10-21-2018, 07:35 AM
  #452
JP-1
Dave Wilshere flying his J.C. P100 Joker at sculthorpe yesterday
Alistair Powers
Old 10-21-2018, 09:48 AM
  #453
Bob_B
Bob_B's Avatar
Nice pics, thanks!
Old 10-21-2018, 03:11 PM
  #454
kekelala
Beautiful photos
Old 10-21-2018, 04:04 PM
  #455
jcterrettaz
jcterrettaz's Avatar
nice shot
Mine arrived Thursday , amazing quality as usual from Carf
Next spring for
maiden
Old 10-22-2018, 02:40 AM
  #456
JP-1
The red looks very nice
Old 10-22-2018, 04:04 AM
  #457
setxws6
setxws6's Avatar
Finally maiden mine on Saturday. Weather conditions were okay but not great. Overcast with low cloud ceiling around 300-400 foot with a slight mist every so often. Winds 10 mph. So I had to keep it low, which is where I normally fly but like to make big verticals too.
The Joker basically flies like a light weight Ultra Flash, just not as fast, but flies like its on rails. Landings are hands off easy just like the UF. Mine is powered with an older Jet Central Rabbit VT90 gas start 19lbs thrust. Full of fuel it weighs in at 21 lbs
Old 10-29-2018, 08:24 AM
  #458
kevin
Guys, I have looked through the thread for ideas on tray layout and have seen a few pics that gave me some ideas. How about a few more? ... post pics of your tray layout. thanks...
Old 10-29-2018, 12:35 PM
  #459
jcterrettaz
tray is made with carbon fibre , balsa and 1/64 plywood ..very light
here few pics of my installation ..im not a master but everything work and the jet balance perfectly
made a removable tray for the 2 Life pack (RX) and one 2000 2S lipo for motor (VT80)
connect the brake on multiplex connector but not the retract ( easy to plug for my setup)
left and right side get one multiplex connector each
still some tidy to do but not much
The Joker is very light ...upset because its already snowing here, and will be a long wait until I can enjoy this beautiful jet
Old 10-29-2018, 12:39 PM
  #460
jcterrettaz
one more
Old 10-29-2018, 01:03 PM
  #461
Dave Wilshere
You must be nose heavy?
What capacity are the packs in the nose cone?
Old 10-29-2018, 01:19 PM
  #462
kevin
My question as well. I sure hope I dont have to put the batteries all the way up in the nose (k100) ...was planning on the front end of the main tray.
Old 10-29-2018, 01:22 PM
  #463
kevin
Although decent enough, it still bothers me a bit to see carf still has wheel cutouts that are not as clean as they could be. Here is a quick fix to make the openings look better and more round. Great planes sticky back sandpaper on the side of the cup...
Old 10-29-2018, 02:00 PM
  #464
jcterrettaz
not nose heavy...CG 175 mm
they are small pack life 1800 and they look far but they are not to far inside ..the tray weight 25 g
Old 10-29-2018, 02:05 PM
  #465
Dave Wilshere
Depends on battery size. I think the KT 100 is a lot heavier than the JetCat I have and the batteries are in the nose, but small. Keeps things light overall.
Old 11-02-2018, 05:52 PM
  #466
setxws6
setxws6's Avatar
Got 10 flights down on my Joker so far, flies like a slower flash, really liking it more and more. Put a Dynamite gps in it and it did 188mph flat out with my 19lb turbine it her. I don't use gyros in my jets but I noticed it does have a little yaw rock back and forth at times, are you guys experiencing this? I figure its either from the large intake inlets or possibly design of the vertical stab.
Old 11-06-2018, 07:57 PM
  #467
kevin
Finally getting around to laying out my components. I have never had a UAT mounted flat. Any issues with mounting it flat and not at a slight angle? I also see a few that have it mounted so the front faces the tank instead of the nose, any cons to that? While we are at it, any issues mounting it straight up and down?
Old 11-06-2018, 10:15 PM
  #468
Dave Wilshere
Kevin
Depends on the make of Bubble Trap. My preferred MAP version can be mounted flat, BVM versions like to be mounted at an angle, so the feed nipples are the highest point (where the air would be when filling) but the rule should always be during the first fill of the system the feed nipple to the main tank is at its highest point. Once a bubble trap/UAT is full it should pretty much stay that way. Because the feed/pick up is in the centre of the tank it does not matter which way around it’s mounted-even vertically.
Dave
Old 11-07-2018, 05:46 AM
  #469
kevin
The reason I asked is my plan at this point is to use the uat I bought from pacific rc jets. With the nipple location and round sides I didnt see an advantange to mounting it at an angle.
Old 11-07-2018, 05:49 AM
  #470
Dave Wilshere
That is designed to mount flat.
  #471
Dansy
My Feedback: (53)
Dansy's Avatar
Dirk mount those flat in his T-1...
Old 11-10-2018, 08:37 AM
  #472
Anferny28
Has anyone installed the front gear door yet? If so how and what did you use. Thanks in advanced.
Old 11-10-2018, 09:21 AM
  #473
Dave Wilshere
Mark Brown did. Flat hinge and block of wood on door to push it forward as the leg goes down. Rubber band to hold close. Look at an original Flash manual for clues
Old 11-10-2018, 10:31 AM
  #474
F1 Rocket
Nose gear door installation.
Danny
Old 11-10-2018, 06:12 PM
  #475
jcterrettaz
Nice I will do the same ..thanks
