T-3 Pics and Build
Nose gear required shimming to fully retract without interference. NG door servo installed to complete NG installation.
Lighting controller installed.
Fuel shut off valve installed.
Air lines plumbed to retract and brake valve.
Servo leads routed through equipment tray in preparation for CB200 installation.
PS...the photos are hard to load on RCU in correct orientation. Apologies for those that are rotated or distorted.
Lighting controller wired up.
Servo leads connected to CB200.
Cortex Pro connections made.
Antenna mast for receiver 1 antennas to get them as high as possible in canopy area.
Smoke pump installed.
Battery cables started.
#34
My Feedback: (53)
Simple enough second icon from the right (paper clips) that bring you to manage attachement...choose files, press upload, check to make sure it did.....close window and preview post to check.....
#39
My Feedback: (162)
Glad someone is posting about the t3. It looks like a great alternative to the havoc and a couple thousand less. I was starting to wonder about the t3 as it came out about the same time as the havoc and you don't see anything about it but there are a bunch of havocs out already.
#40
Yeah, like half the price. JS
#48
Almost done! Weight and balance time. Light system check. Started programming.
Pretty happy with the weight ... two pounds lighter than reported prototype weight...of course it had a 310in it! Tends to be tail heavy ...all batteries in nose to balance. Glad there is a hatch in nose!
Canopy to be painted tomorrow.
Some photos also with the two together ... mine and my buddies.
JS
JS
