Welcome to Club SAITO !
#9502
My Feedback: (24)
RE: Welcome to Club SAITO !
ORIGINAL: sarashina
Mr. Gen Saito who was the founder and the chairman of Saito-mfg.co. passed away on November 29.
#9503
VA
ORIGINAL: c-crunch
too all of you guys. i have been looking at a new saito. and i am tor between the 220 and the 180. i guss the the qusthion is dose the 180 have the power to pull a 15 lbs. plane around with desent proformce? c-crunch
#9504
TX
Hi all! I have an older Saito 72 that WAS running well. I'm running it with a 13x6 3-bladed prop at approx 10K rpm on 20/20 syn fuel. It started leaving a black residue from the exhaust (the last three or four flights). I understand that this is likely the result of metal to metal shaving. Where are the likely instances of contact and what are the likely parts that will need to be replaced? Has too much damage already occurred? Is there a manual that will guide me step by step on the engine breakdown and rebuild process?
Previously on transition there was plenty of white smoke that cleared to a light smoke as FT was reached. Now, without any adjustment in excess of half a turn to the previous setting on the HS it wants to die as it approaches FT. Was it too lean? If not too lean, what was the likely cause?
Any and all guidance will be appreciated.
#9505
I thank for condolences from all of you.
I want to serve to tell condolences of all of you to Mr. Saito's family and the employees in Japan.
#9507
ORIGINAL: sarashina
John
#9508
IL
Hi everyone. I received a GP P6-E Hawk for Christmas, and I am trying to pick out a four stroke for it. The manual recommends a 19.5-23cc four stroke. Its flying weight is listed at 14-16lbs. I was looking at the Saito 125, coming in on the low end of that range. Also, the Saito 150 comes in at 25cc and weighing about 8oz more, from what I could tell.
The 125 seems right, but I saw two instances last year at my field where an underpowered plane got off the ground (barely) and then went right back down, badly. I don't want that to happen here, but I'm wondering if the 150 is too much or too heavy in this case. Thanks in advance.
#9512
AL
Does anyone know if there is a Saito rep? I am replacing a spray bar in a Saito 100 and am not sure where the small o ring goes...also does it matter how the hole is positioned ?? Also is there a diagram anywhere on line that may show an expanded drawing of the engine?
Thanks Gene
Thanks Gene
#9513
GA
#9514
My Feedback: (16)
ORIGINAL: echomike1947
Thanks Gene
Thanks Gene
There are several O-rings that come with the gasket set but only one that comes with the spray bar
The one that comes with the spray bar is rather skinny. After you have the spray bar in place, the O-ring goes over the spray bar on the outside before you install the ratchet spring and retainer nut.
#9515
TX
ORIGINAL: c-crunch
#9516
AL
Hi, you seem to be a Saito expert...can you tell me on which side of the spray bar does the o ring go? Also does it matter how the hole in the spray bar is oriented?
Thanks Gene
Thanks Gene
#9519
TX
ORIGINAL: c-crunch
ok everyone. what kind of airplane would be a good one for the 180. c-crunch
http://www.horizonhobby.com/Products...ProdID=HAN4175
http://www3.towerhobbies.com/cgi-bin...?&I=LXDJE1&P=0
http://www.extremeflightrc.com/html/74yak54.html
#9520
VA
Yeah I Have a Extreme Flight Yak with a 180 inside .Spinning an 18x6 Xoar . Takes a little bit of work Unless you get a regulator to work with it.
I moved my tank under the wingspar @ Cg to get it low enough then put on a pump. Works great .the plane has good power also.
http://rcuvideos.com/item/YPMMRM72CHZDBS41
#9521
OR
Ihave a Saito FA-82 with about three hour on it and it is blowing blackened fuel/oil from somewhere other than the breather or muffler. It is running great but making a huge mess
and starting to worry me. I have other Saitos and have never seen this before. Help!!!
OH
Terry 5, Have you done Funtana 100x with a Saito 180? I am about to Build one and any tips on installing this beast would be appreciated! Thanks,Mike
#9524
Well, I have a Saito 220 gaser , and a Lanier Ultimat Pitts that I am building. My friend said stick a 180 glow in it and it will fly great.... So I liked the idea of gas & 4 Stroke ..... So I bought the 220 gaser from Saito. What do you guys think? Is it a match or over kill? I've almost built all except for the radio stuff, waiting for UPS and my new Radio, I am weighing 10.5 lbs. ready to cover less radio. I guess a couple more Lbs. and it will be flying. I post some pics.
#9525
TX
ORIGINAL: frequent flyer
