Welcome to Club SAITO !
Old 08-29-2017, 07:41 AM
  #34576
FlyerInOKC
FlyerInOKC's Avatar
The sensitivity should lessen with time keep at it.
Old 08-29-2017, 09:36 AM
  #34577
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I think that when they stop being a bright pink they'll feel better, or less you might say.
Old 08-29-2017, 09:51 AM
  #34578
acdii
Quick question, I don't need to start a new thread for. On my Gemini, can I use blue thread locker to secure the screw that holds the arm to the throttle body? It came loose in flight and caused a crash.
Old 08-29-2017, 10:21 AM
  #34579
BarracudaHockey
BarracudaHockey's Avatar
As long as the screw and internal threads are metal yes and a little dab will do ya.
If you're screwing into plastic then no, locktite will attack and make plastic brittle
Old 08-29-2017, 04:20 PM
  #34580
N1EDM
Overall, the engine has been cleaned up nicely. It was just the valves that were rather gunky. Since that last post, (34524 and 34525 on page 1381) I have run the engine up with a 13x6 prop and got about 9300RPM on it. I think that was pretty good, actually. I just didn't want to pull the valves (and lose the springs) unless I had to.
I'd heard that one should try squirting some WD-40 into the intake, and other guys said not to do this. Has anyone heard of this, one way or another???
For the record, I use Denatured Alcohol quite a bit for cleaning a lot of things, but it's not that effective at getting deep castor oil off.
Thanks for the input,
Bob
Old 08-29-2017, 05:34 PM
  #34581
acdii
I heard WD-40 can damaged the orings in the carb and intake.
Old 08-29-2017, 07:33 PM
  #34582
the Wasp
you can see in this photo that engine has only 2 plugs, also if you read the article you will see that engine has a very efficient Combustion Chamber in the shape of a Hart (same as the Chevy SB), I don't think mine with the dual plugs will have that Compression Chamber, I'm thinking mine is an older engine, it would be nice to know,,
Hobbsy, would you know when Mr, Lee wrote that article ??
Jim
Old 08-29-2017, 08:12 PM
  #34583
the Wasp
Hobbsy, it's good to hear that your hand is healing well !
a 20x8 on my MVVS 35cc hit my finger at a high idle, the prop hit the end of my finger but on it's side, it hit so hard it split open the underside and broke the tip of the bone, it took 4 stitches, that must have been ten years ago..
Jim
Old 08-29-2017, 09:02 PM
  #34584
the Wasp
check out the sound of this baby !!
Jim
Old 08-30-2017, 02:05 AM
  #34585
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Post
Jim
I be confusssseed, the 1.82 Mr. Lee tested has dual plugs, good catch. I'll do some diggin on the date of that article. I am using my fingers more each day, I need to take my Harley to Hector Inspector's for the annual State inspection, working the front brake will exercise them some but not much, it has powerful brakes with little effort required. It's 10 miles up there but will be 100 before I get back.
Old 08-30-2017, 03:04 AM
  #34586
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Bob
Saito FA-65 update model
You're right in the ballpark, Clarence Lee got 9,250 with a Rev Up 13x6, You done good.
Old 08-30-2017, 03:29 AM
  #34587
N1EDM
Thanks or the feedback on the FA-65 acdii and Hobbsy.
Bob
Old 08-30-2017, 04:37 AM
  #34588
Rudolph Hart
Rudolph Hart's Avatar
Not likely but the aussie version might
Name:	start ya *******.jpg
ID:	2229860   Click image for larger version
Name:	start ya *******.jpg-1.jpg
Old 08-30-2017, 05:05 AM
  #34589
FlyerInOKC
FlyerInOKC's Avatar
Catchy name!
Old 08-30-2017, 05:00 PM
  #34590
the Wasp
Hobbsy, but I am talking 130 size, the engine in the photo I posted is the 130, (not the 182),, and mine is a 130 too
Jim
see my engine here
Old 08-30-2017, 05:48 PM
  #34591
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It appears that some 1.30's had dual plugs and others like yours did not, at least that's the picture I'm getting.
Name:	Saito 130 DP.jpg
Old 08-30-2017, 05:59 PM
  #34592
the Wasp
mine has 4 Plugs,
I'm now wondering, because Mr, Lee did not talk about the fact that some 130's do have 4 plus, maybe the 4 plug engine is a newer engine than the one Mr, Lee tested,
edit>> surely if the first 130 had 4 plugs Mr, Lee would have said so in his article..
BTW, my engine cleaned up well with Auto Engine Degreaser,, plus, I pulled a Plug on each side and I added a few drop of ATF, and this little baby has very good compression
Jim
Old 08-30-2017, 07:38 PM
  #34593
blw
blw's Avatar
Pete, nice work with the logo letters and nice look of depth. That is really great looking. I might detour over to the Triumph bike shop tomorrow and just look around.
Old 08-30-2017, 07:43 PM
  #34594
the Wasp
slick !!
Old 08-30-2017, 07:49 PM
  #34595
the Wasp
even better
Old 08-30-2017, 09:01 PM
  #34596
the Wasp
did you guys see this photo
Jim
Name:	f6 flyinggiants.jpg
Old 08-31-2017, 02:20 AM
  #34597
Rudolph Hart
Gee i dunno barry is that safe to do? triumph make retro bikes that take you back to the sixties with rose coloured glasses,anywhere close to the dealership could be fatal,specially if the minister for finance/fun is'nt prepared.You are surrounded by motorcycles and a slick salesman appears with a white open faced helmet and a set of brown flying goggles that fit you perfectly.He says 'take it for a spin' and the next minute your transported to heaven.You ride it home and pull in the driveway happier than you've ever been,give it a rev to make sure the neighbours noticed and proudly walk up the front steps as the missus opens the front door.How big can a fully loaded and cocked judge look and whats with the red laser dot
Old 08-31-2017, 03:10 AM
  #34598
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Barry, if you go there think big, like a Triumph Thunderbird Storm, 98 hp and 115 ft. lbs. torque. 1,699cc. Your Mrs. will love the the tourer.
Yes Jim, I was thinking per cylinder, your way per engine may be clearer. Bill Robison was convinced that if you put a cold plug in the front of cylinders you could have a sort of ignition curve, no way to prove that, that I know of. We discussed that because my 1.30 had four plugs. Some of the 1.20's had twin plugs too.
ID:	2229969   Click image for larger version
Old 08-31-2017, 04:57 AM
  #34599
FlyerInOKC
FlyerInOKC's Avatar
I'll take the bike on the right!
Old 08-31-2017, 05:39 AM
  #34600
acdii
I'll take the Soup!
How many know where that came from?
